Hi, I am looking for the name and contact info for a good qualified yacht surveyor for a boat that is sitting in ny. I would like him or her to be qualified to also test the engine. Can anyone provide info. Thanks for your help.
The idea(s) are actually twofold:Many of the surveyors do an oil test here. You can get a kit on line and get results back fairly quickly. Idea is to get a better idea of engine wear.
The idea(s) are actually twofold: 1. A SINGLE test will tell you if there is any METAL in your oil, indicating something major is disintegrating inside the guts of your engine. Metal shavings in the oil? Hmm, not so good. Water shows up, too, but if your oil is milky, even YOU can figure that one out.2. ONLY MULTIPLE oil samples over a period of time without oil changes can give you an idea of the TRENDS in the quality of your oil. A single oil test just is not the be all-end all. That's all.
