I would expect that acetone cut right into the casing. I had new lifelines done two years ago, and the only thing that I use to clean them is the same thing that I use on my hull. I use Meguire's "50" Cleaner Wax on a rag and they come out like new.
A little off the subject, but last fall I used acetone to clean the black, sticky goo off my old yellow AC cable. The cable came clean very easily with no after-affects from the acetone. When in doubt, try it on a small inconspicuous spot first.Ken, S/V Liberty
