The 1998 C-42 should have come with a DUTCHMAN...
... and even if not currently there, you may be set up for it.Hi, Gaston--My '98 C-42 came with a DUTCHMAN reefing system. If not currently installed, your "98 C-42 should be DUTCHMAN-ready. Check your main. If it is the original Catalina-supplied sail, there will two rows of plastic-reinforced eyelets -- about 8 or 9 forward, 5 or 6 aft. If so, you are set. All you need is to order the appropriate topping lift and fittings from DUTCHMAN in CT. The topping lift is fitted to the mast head with a small tackle attached to the boom-end of the topping lift with the running end of the line reeved through the boom, through a block at the mast collar, through the line organizer, to a line clutch. A topping lift is perfectly compatible with a hydraulic or any other kind of vang because it usually isn't used as a topping lift, but as a support for the Dutchman lines which reeve through the eyelets in the mainsail.So, rather than a spiderweb of lazyjack lines, you have two nylon "fishing lines" from the topping lift to the foot of the sail. Adjust the vang and let go the halyard -- the mainsail practically folds itself on the boom. It has to be seen to be believed. Placing the sailcover is easy because there are just two slits in the cover to accomodate the DUTCHMAN lines.I swear by it!Good luck--Ernie AprilWindCatcher, C-42 #618
