Lancer 45 rudder bearing
patcda
Aug 10, 2011
2
Lancer Center cockpit St-Lucia W.I.
The rudder on my Lancer 45 is very stiff. Would anyone know how it is built. I suspect it is a plain bearing made of a plastic material that has swelled during the years in water. Am I wrong??
Jun 8, 2010
31
Lancer 28 ATX
try spraying wd40 around and inside from the top of the rudder allowing it to seap into the internal bearings and o rings to clean and lube them up. This should allow it to loosen up and hopefully give it some more life. You might have to replace the rubber/plastic o rings that seal the boat from the water. If you have had it out for a long time it might be good to replace the internal rubber. If its grinding sticking and making noise you might have to change some sprockets or chains or etc...
