Hello,
Here is the scenario.
Brand new starting battery, charged through bulk (14.5v) to float (13.5v) using my "intelligent" battery charger.
Brand new house battery, charged through bulk (14.5v) to float (13.5v) using my "intelligent" battery charger.
Bring both batteries to the boat and install (same day). Batteries connected throug a Blue Seas ACR. Hook up solar panel (Kyocera 135 watts). (SunSaver 20 amp PWM controller)
No load on house other than DC panel lights and automatic bilge pump switch set to automatic.
Solar charge controller voltage immediately goes to 14.6v. Let it go for a few hours. Motor out of marina to go sailing. Voltmeter reads 14.6 volts with engine running. Cut motor and sail around all day (bright sunny day) with solar charging at 14.5 volts. Only the depth sounder (Raymarine ST40 Depth/Speed) turned on.
Here's the question: Shouldn't the solar controller have dropped the voltage to 13.5 volts at some point given the batteries were fully charged before installation and that the alternator and the solar panels had been charging during the day? My concern is that I will overcharge the batteries. Question 2: Should I stop worrying about it?
Thanks
Thanks
