irwin 37 compression post
383
Irwin 37' center cockpit cleveland ohio
I need to find out what the length is of the compression post. Mine is two 2x4's nailed together. Something happened to my boat and I would like to replace it.
Jun 13, 2005
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
My Post
My post is an aluminum Pipe painted white which is not generally accessible but I got into the post compartment through an access for some wiring and measured up and down until I hit something; then I got into the bottom support area and made some measurement adjustments. The best I can tell my compression post is 6'-6&3/4"from the top of the base plate to the bottom of whatever I hit when I measured up. That's about the best I can do. Good Luck ---Joe
