Interior wall pieces
Nov 28, 2012
148
Catalina 22 #442 Somerset, Ma
What type of wood is this? im going to remaking some of the interior wood pieces and i know most are teak but those the the seat backrest look like plywood with a veneer on the front? all the interior looks original im just curious. i may just go with plywood and a veneer. not to sure yet
Nov 28, 2012
148
those little walls ( probbaly not the correct name but you get my drift)
also was this a stock little rack/shelf thats under the port side cockpit hatch/ behind the backrest on the portside?
128
Catalina 22 Clucluz Lake, BC
Marine plywood with a fake teak veneer. Teak plywood can be purchased but its very expensive, I was quoted $160 for a sheet. I built replacements for all of my plywood pieces from regular 1/2" red oak plywood instead. For the table and step I used 3/4".
Nov 28, 2012
148
those looks GREAT!!!
160 for a sheet isnt going to happen for me..lol Did you find the 1/2 to be big enough or too big?
Thats exactly what i want to do this winter though, get the whole inside replaced while she is wrapped up. ive taken 90% out already for templates
Dec 23, 2008
771
Catalina 22 Central Penna.
Check locally for MDO plywood.
MDO is masonite laminated on top of plywood to give a very hard and smooth finish for any kind of paint or stain.
MDO is used by the sign industry for outdoor signs, better wood and glue than standard outdoor or marine plywood, all those green directional and location signs along the Interstate Highways use to be MDO plywood.
Nov 28, 2012
148
awesome info,the step board has a crack in the fiberglass from years of wear. going to re inforce that area when i fix it. Why it doesnt have some sort of support behind the lip is beyound me. it seems like a high use, high weight area.
Sep 29, 2012
128
I found the 1/2" to be a tiny bit too thin when I reinstalled the solid teak edge trim on these pieces however I believe 5/8" would have been too thick. Perhaps Catalina used regular thickness 1/2" and then added the additional fake teak veneer which resulted in the original pieces being thicker? It wasn't a big deal though. Rather than staple the trim back on the way it was originally installed and risking splits or protruding staples I used 4200 and just glued it on. This helped to compensate for the fact that they wouldn't have fit snug.
Nov 19, 2008
2,129
Catalina C-22 MK-II Parrish, FL
Nice work Whatcaneyedo! Would like to see some more photos. What a clean looking interior!
Don
Nov 28, 2012
148
def looks great, cant wait to start on this project.....one of many winter ones..lol
Nov 28, 2012
148
How about the shelf/rack under the cockpit portside,behind the seat in the cabin?
Nov 28, 2012
148
sweet, its pretty neat, ill have to get some better pics, it runs the whole length of that compartment. keeps things nice and neat
Dec 5, 2011
557
Catalina Catalina 22 13632 Phenix City
I replaced the starboard bulkhead and locker fronts in "Kellie Marie" with 1/2" mahogany plywood coated with Cetol and it looks just like or better than the original wood. It was $80 for a full sheet at my local lumberyard and the original teak trim fit right on it without a problem. As long as I keep my chainplates and hatch boards tight, I fully expect to get another 27 years out of my work.
148
wow that looks great slim. its nice seeing the different approaches to fixing the issue
Bilbo
Aug 29, 2005
1,265
Catalina 22 Ohio
One of the first things that I had to do was replace both bulkheads. The originals had rot along the bottoms. I stained some better quality 1/2" ply and coated the pieces with West system. This included the insides of the bolt holes for the shroud straps.
Not sure if this is accessible but here goes:
http://baggins.150m.com/Sailing/C22_Bulkheads.html
Dec 5, 2011
557
It's all still there Bilbo, matter of fact, your page quoted above was one of the first ones I looked at when I discovered my SB bulkhead was rotten. It gave me enough info to see that it wouldn't be a bad job to tackle and certainly with in my abilities. BTW, your cushions look great, I'm envious!! This winter I'm slowly re sewing new covers for the worst ones on my boat, you know, the ones with foam showing through....
Bilbo
Aug 29, 2005
1,265
Catalina 22 Ohio
Thanks. Actually some of the cushions need some work. The table seat by the entrance is kinda ripped from sanding on it and the ones by the bulkheads where they got a bit wet are rotted a bit. I'm thinking about seat cushion covers. Maybe some of that clear vinyl like they used in my grandparent's living room.
Nov 28, 2012
148
i like the fullbulkhead you did, thinking about doing the same to mine on that side.
Nov 19, 2008
2,129
Bilbo,
I looked at your blog on the project. That's really nice! We've converted our V-berth area to an enclosed head and luggage storage. But, and full bulkhead on the portside would be nice. It would add to the "pottie-privacy", and give us some additional storage space. I wonder how my Firstmate would react with her claustrophobia? Maybe some wooden louvers in the bulkhead would help, and help with cabin ventilation.
I've attached a photo of our forward section on the boat showing the head and luggage storage from last weekend.
Nice work!
Don
148
looks good Don,
The louvers are a good idea. im afraid of it being to dark on my non hatched boat in the vberth with a full wall. Well maybe a hatch is in the project now..lol
