Installing chart plotter
1
Hunter 29.5 Poulsbo, WA
Has anyone installed a chart plotter on a 29.5? Where did you mount the display and how did you access a power source?
Mar 20, 2004
1,746
mounted mine on to of the pedastel forward of the wheel-the cross bar in the pedastel is aluminum so you can drill and tap. power wires were run along the shifter cables down below and then to the breaker panel
May 11, 2012
53
hunter 29.5 napa ca
I made a bracket and mounted a E 7 raymarine above the compass It works well for me there
May 1, 2009
96
Hunter 30 Groton, CT
I mounted mine in the drink holder. Seems like the better would be forward of the cabin entry hatch. Top should remove will be inspecting and could add photos next month.
