Installing cam cleats
5
- - Chocowinity, NC
Guys, I have a 2004 Hunter 306, which I often sail alone. I hate the cleats for my jib, because I have to leave the helm to reset them. I want to replace them with cam cleats, which I liked on my last boat. I've never replaced any deck hardware. Any suggestions? Do I have to remove the fabric ceiling in the cabin to access a reinforcing plate (if so, how do I remove the ceiling?), or can the whole thing be done from the deck only? Thanx!
Dec 2, 1999
15,184
Normally there is a backing plate that is embedded in the fiberglass. You need to drill and tap the area to mount the cam cleats.
Jun 4, 2004
41
Hunter 33 BLSC
I'm not sure I understand. I have self tailing winches on my 28.5 and no need for cam cleats.
Clark
Jun 30, 2004
882
Hunter 280 Lake Guntersville, AL
John, your boat is very different from Orcon's 306. Go to Boat Information and check out a few pictures of the 306
Clark
Jun 30, 2004
882
Dan,
As a followup, there will be times when the cam cleat will be overstressed' even with the smaller jib you (and I and others) have. For those times, you have to use the self-tailing winches on the cabin top.
