Marvin
Having a major problem with the inboard diesel on the boat. Mostly it will run at idle in the slip, put it under a load and about two minutes to three minutes is the max. Also it smokes like a smoke stack. Not so much through the exhaust but back through the cabin. I have gotten on the list for the local machanic. Anyone with experiance with the inboard diesel in a old 25 footer.Also this engine does not have a shut down lever or control. Is this common with this type of engine. Thanks Marvin.
