The molded threaded plastic key entry part of our ignition switch has broken away. As a result, the threaded plastic collar has nothing to screw onto leaving us no alternative but to tape the switch back into place until replacement parts can be found.
Does anyone have a go-to source which you would recommend for such parts. It is a Yanmar 27 that Hunter put into most of their 356's.
(I probably should not be too upset. Without the key entry pieces and as long as the tape holds out, I can start the engine with a screw driver.)
