Hunter 45CC davits
Nov 19, 2009
289
Hunter 45CC Ft Pierce and Abaco Bahamas
Do any of you have a 45CC with a davits? Which manufacturer? Never again or do it again?
Nov 19, 2009
289
Thanks, I'll check them out. What was the installed cost?
Apr 11, 2012
324
Cataina 400 MK II Santa Cruz
I have Forespar Nova Davits on my Catalina 400. They are very good.
Jun 1, 2009
1,746
Hunter 49 toronto
Likes: RWSlater
MitchM
Jan 20, 2005
1,020
Forester nova davits are great. they fold easily for winter storage or minimizing your dock fees. be sure to get stainless steel backing plates, --not aluminum-- if you are on salt water. aluminum back plates used with stainless davit mounting bolts are a recipe for corrosion.
Likes: RWSlater
May 18, 2016
5
Hunter 36 Charleston, South Carolina
I installed Forespar Dinghy Davits and the Nova Lift on Hunter 36. Davits took me about 4 hours and the Lift took about 2 hours. I love both of these items. If you have a 4 stroke engine, I highly recommend the Nova Lift. The 8HP Tohatsu that is pictured, weighs around 80 pounds and I really struggled before I had the Nova Lift.
Likes: RWSlater
Davits are nice and my boat came with them (not put to use yet), but I am beginning to give Terry's idea of attachment to the transom a look. For his boat it did not extend the length of the boat. Could save on dock fees.
Lashed, the dinghy is not just hanging there, adding to weight balance or movement, it appears to be securely lashed to the stern. I guess it is an issue of conditions. If weather is in flux, I think the lashing of the dinghy to the hull might make for a safer passage.
Likes: RWSlater
Les, your choice of davits has merit when I look at mine. There is a bar holding the davits apart. Mine are not so separated. This does allow me to swing them together flattening them from protruding beyond the transom and onto dock space. In use, the lines would draw against the outsides of the dinghy thus keeping the davits spread. This will be a project needing consideration for this summers cruising plans.
MitchM
Jan 20, 2005
1,020
'There is a bar holding the davits apart.' that is a stabilizer to prevent torsion , supplied as an extra by most manufacturers. i am thinking of adding 2 to the fore spar davits to hold a solar panel..
Nov 19, 2009
289
I decided to go with Kato Marine Island model. They live in the neighborhood where the boat is now and they recommended a rigger that has done several 45CCs. We are going to raise it 18" due to the high transom and to also try to adapt a motor life with the davits having solar panels on top. Should be installed next week. Thanks everyone.
Likes: Doug4bass
Jun 9, 2004
615
Catalina 385 Marquette. Mi
You are gonna love da Kato's. Dont forget the torsion bar. If you are planning on keeping the motor on the transom of the dinghy, also get the larger purchase blocks on the motor side of the davits. And maybe the additional supports?
Torsion bar wasnt added yet in this photo.
Likes: RWSlater
Nov 19, 2009
289
Yeah I got the upgraded blocks both sides, the braces and the torsion bar will actually be where the solar panel mounts are. Also got the clam cleats in case I'm singlehanded. I'm also coming up with an idea for an additional brace to even make the davits stronger
