Check Out this...
Check out and print the Yanmar Tips from Curt Morris on the home page of this site.Also,1. There are at least 3 Yanmar web sites, that I know of, that people can use for research/contact regarding Yanmars:yanmar.commackboring.comtorresen.com2.Some diesel distributors offer one-day seminars on diesel basics. This is worth the investment just to do the regular maintenance and they give you enough info to get yourself out of trouble if something minor arises (bleeding system, change impeller, troubleshooting).3.The CD oil type is getting more difficult to find in some locations. I spoke with MackBoring salespeople and they informed me that any type GREATER THAN CD (e.g. CE, CF, etc) can be used in place of CD.4.In the cooling system - an owner should note the normal water flow discharged by the engine. If there is restricted water flow coming out of the exhaust, or white steam, this is an indication of a restriction. In the last two years, I have twice found debris (eelgrass) plugging the 90 degree elbow that goes INTO the strainer. This wasn't immediately identified until I disconnected the hose from the strainer.Sometimes, the thru-hull is clogged and I must poke a wire (backwards) into the valve to free it up. Or reverse flush it with a high pressure water nozzle (now standard equiptment in my cockpit locker). There is no external hull strainer on my boat.It would be a good idea to purchase the service manual from Yanmar (about $40) for your engine. It is very helpful for detailed info re: how often certain maintenance should be done.
