HUNTER 170
Hi, has anyone tried to put additional weight to the center board( keel) of hunter 170 to improve stability, to sail alone less stressfully, or replace the blade with inox one , filled with plumb?
Jun 6, 2007
5
170 Keel
You may want to check out the Archives under H170 and search for keel. I know early 170's had a still lighter keel and some weight has been added. This is discussed at length in the archives. Good luck.
Oct 2, 2006
83
Hunter 170 Kentucky
Reef or sail under main sail alone...
Anton,
I sail my 170 almost all the time alone. If I think the wind is getting too high I'll just reef or most of the time I just roll up the jib. The boat loses a lot of power without the jib and is easier to handle.
Tim
yclaes
Hunter 170 -
Hi Anton,
I have been thinking about the same as I find the H170 not very balanced.
Did you find a solution in the archives ? Where can I find the archives ?
Thanks,
