Hull-deck joint on Bristol 24
The hull and deck both have an outward flange that is glued and stapled together with heavy stainless staples. To reinforce or permanently cure any leaks, you could remove the rubrail and put fiberglass tape over the joint. This would require a lot of fancy grinding or sanding to give the resin good holding on the flanges. Then reinstall the rubrail or replace it. I have not yet tackled this project on my Bristol 24, but it is something (far down) on the list of to-do's.Have you made a modifications to your boat?
