Our water tank leaks when it's filled more than about half full. The S2 manual states that the tank vent terminates in the anchor locker, but there appears to be no such connection between the tank and the locker. There is a fitting with what appears to be some sort of venting valve, but not connected to anything. We were hoping that this might be the problem (water leaking out of the unterminated vent when heeling). However, we plugged off all inlets and outlets and tried to pressure test the tank, but never were able to build up any pressure at all. Thus it looks like the tank has some sort of serious leak - maybe a burst seam or corroded through. The tiny parts of the tank visible through holes in the bulkheads don't show any corrosion though.The tank is quite well buried under the V-berth. It appears that some serious fiberglass surgery will be required to even see what is wrong. We would very much appreciate hearing from anybody else who has tackled a similar job in an S2. How much cutting was actually required? Will the tank fit through the door to the V-berth even after getting it loose? What was the actual cause of your leak? Did you repair the tank or replace it? What's up with the missing vent line?Any advice appreciated.
