hot water tank
Nov 26, 2008
1,970
Endeavour 42 Cruisin
Raritan 6 gallon hot water tank keeps overflowing out the pressure relief valve...the new raritan pressure relief valve I installed to replace the old one that I thought was defective. Raritan tech support thinks it may be sediment built up inside causing the overflow, on both engine heat AND dock power.
So I have 3 choices. Try to repair the old tank, a 2001 vintage, buy a new raritan replacement for $800+ or buy a Seaward tank for about $300. Dont feel like dropping $800. Wondering which is more reliable, a 15 year old raritan or a new Seaward water heater. Anyone with reports on Seaward tanks?
Our C34 skippers have vast experience with them. Our information indicates that the Seawards last anywhere from 10-15 years. When we bought our then-12 year old boat in 1998, the PO had just replaced the Seaward heater. I replaced that one in 2013.
The basic choices:
1. Kuuma - a low level copy of the basic Seaward, not highly recommended, but cheapest
2. Seaward and Raritan - middle of the line, Raritan a tad better but not $500 worth more.
3. Isotemp - great units, wonderful insulation, come with thermostatic mixing valves on the output
Your boat, your choice. :)
PS - If your PRV is popping, then your water is too hot. There is NO need to keep the electric working all the time; heat the water, turn the power off; it only takes about 15-20 minutes to heat the water. PRVs have been known to fail when "exercised," which is why there is no reason to do so; crud gets in and keeps it open. If you have crud, it means you heater is failing; 15 years is at the end of its useful service life.
Likes: gettinthere
Oct 26, 2008
6,277
Catalina 320 Barnegat, NJ
It seems that Isotemp gets better reviews than other brands AND is more economical. It sounds like a no-brainer to me.
GE,
I just reviewed a variety of heaters and selected a Quick Windlass BXS2512SL. $670. Rated highly by Practical Sailor. A number of good reports by boat owners and Cruisers. The unit's water heating capacity and recovery speed let me go from a 10-15 gallon unit down to a 6.5 gal unit.
Reasons for selection.
  1. It was a square unit and fit in the space that I am removing the water heater from 1974
  2. 316 stainless steel tank, argon welded for corrosion resistance
  3. 304 stainless steel case - could have gone with a painted or galvanized case, but the 304 stainless was only $30 and available to ship.
  4. Heat exchanger is a thick walled (1/16"), coiled 10 ft. tube of 316 stainless steel, so it won't compromise the engine cooling system or the hot drinking water.
  5. Insulation is 2" of high density polyurethane foam - Boat owners reported the water stayed above 120F upto 20 hours. Heat today on engine have hot water tomorrow for breakfast dishes without shore power.
  6. All units are 1200 watts; 110 VAC - When on shore power quicker to heat your water.
We each make our compromises as we outfit our boats. My plan is this is a one and done for me as long as my hoses hold out.
Did find that the connections on this unit are British Standard Thread. Gave me a fit until I learned that the distributor supplies the connectors with the unit. My supplier was uninformed. Delayed my purchase as all the US thread fittings would not work. Once resolved all is happy.
Feb 10, 2004
4,136
Hunter 40.5 Warwick, RI
I replaced my Seaward after 12-13 years. I had a leaking PT valve that I could not remove. Given that everyone said that the tank was near EOL, I just replaced. I did not spend extra for the SS exterior since the tank is in a protected place.
Oct 26, 2008
6,277
More economical? In what way?
I think I saw the 6+ gallon Isotemps for less than $700. More economical than Raritan. Sure, Seaward tanks are lots cheaper but tanks are aluminum and galvanized steel exterior. I don't like aluminum for potable water & prefer SS over galvanized for exterior. I just bought 5.3 gal Isotemp to install in my boat. Besides, reviews seem to favor Isotemp.
Nov 26, 2008
1,970
There is an epoxy coated exterior option, I dont think that will be an issue in the eng room. But yea, alum interior is not as good as stainless. But is it really an issue? We dont drink out of the hot water tap.
Gunni
Mar 16, 2010
5,937
2003 Seaward HW heater still going strong. I would replace mine with a Seaward. These things are subject to variable water quality and disposable. Mine is effectively a thermos.
May 24, 2004
7,173
CC 30 South Florida
In a scale of 1 to 3 repairing the old tank comes last and the winner is the Seaward; just think you may not own that boat in another 10 to 12 years.
Feb 8, 2014
1,300
Columbia 36 Muskegon
True that ... to a greater extent maybe it's just a matter of personal preference.
The recommendation to never drink or cook with hot tap water applies to home systems with old soldered copper pipe, or really old lead pipes. Solder used to be made of lead, and hot water leaches the lead out faster than cold. So, drinking hot tap water could give you lead poisoning. See the news articles about Flint, MI and their water problems. Slightly corrosive water and homes with lead pipes.
Unless you have soldered fittings or lead pipes your boat, it doesn't apply.
I wouldn't trust a Chinese water heater to not have lead in it. They have a history of using lead where it shouldn't be.
Pretty much I don't trust Chinese anything.
619
Tartan 34C Toms River, New Jersey
I agree with you about the Chinese manufacturing, but why would you drink hot water?
You never need a hot drink and did not want to turn on the stove? Like a two hour run up the Sound into 3 ft chop with temps near 53 and the wind dead on the nose.
The motor heated water can make a great cup of beef bullion in less time than I can stop shivvering.
Beneteau 323 Annapolis MD
[QUOTE="... , but why would you drink hot water?[/QUOTE]
What, you've never had Hot Water Soup?
Gunni
Mar 16, 2010
5,937
We keep an Aladdin SS thermos with hot potable water in the galley sink along with another for hot coffee. A boat HW heater can be contaminated with antifreeze from your engine exchange loop, bacteria, and metals and should not be considered potable.
Jan 4, 2006
7,264
The next time you you're looking at the relief valve and its leaking, open a faucet to relieve some of the pressure and see if the leakage stops.
YES? - the cool water in the tank is expanding as it heats, increasing the pressure, and the relief valve is doing it's job. Install an accumulator.
NO? - reduce the pressure setting on your water pump.
STILL DOESN'T STOP - wait for the next reply.
Scaling on the relief valve seat will cause continuous leakage at any pressure. Do I understand correctly that you have already installed a new relief valve and it also leaks ?
Likes: Hello Below
Nov 26, 2008
1,970
Yes, I have premature ejaculation from the NEW raritan pressure relief valve, when heating water from engine or dockpower. Water pump is 35 psi and I do have an accumulator tank.
Feb 8, 2014
1,300
Could be some crud in it. Try opening it full for a few seconds to blow the crud out. Be prepared to get wet or put a bucket under it.
Jan 4, 2006
7,264
OUCH ................... I'm a little worried I could be banned from this site for even replying to your .............. ahem ............. rather colourful description of the pressure valve performance. :redface: Mind you, a worthy comparison it is and may we assume the discharge is only periodic :( and not continuous ? Aw crap, we're just getting worse here :doh:.
Periodic discharge indicates thermal expansion of the water followed by pressure relief and is a periodic process. Any chance the accumulator could have broken diaphragm or just lost its charge ?
Likes: Hello Below
