When I was pulling the lower unit the vertical shaft that goes from the water pump up to the engine head also dropped out. This wasn't mentioned in the directions I am following. Note this is a 2012 4 cycle.
http://forums.sbo.sailboatowners.com/showthread.php?t=129302
On the vertical shaft end is a square tube to mate with the pump and the other has splines to mate with the head. Is there any trick to getting it back in? Is it very hard? I remember doing something with my old Johnson 6 (it's been awhile) where I had to slowly spin the prop while I was inserting it. Do I do the same thing here? Or do I insert the shaft into the engine then mate up the lower unit?
