Help- Halyard line broke in Roller Furling Selden Mast
  • Thread starter Yvonne Anderson
  • Start date
Y
Yvonne Anderson
I was wondering if the mast had to come apart to re-rig the halyard or if anyone had any advice on how I could find out how to repair this.
C
Claus
Selden Mast - Running Cables
From The Selden Manual (assume you have a Selden): -------------------- quote ---------------------------- All Seldén furling mast extrusions are fitted with a cable conduit. On keel-stepped masts this goes uninterrupted through to the foot. The mast is provided with a messenger line from the factory. Thread a new messenger line at the same time as you run through any new cables. This will ease any future, further, cable running. If an existing cable should prevent a new cable being run it should be extracted, but attach a new messenger to the cable first, to take its place in the conduit. That messenger can then be used to draw two or more cables through the conduit – but do not forget to draw a replacement messenger through at the same time. Cables are fed into the conduit through a hole in the mast wall by the head box. Cables should be over-length to allow subsequent removal of the head box without electrically disconnecting masthead installations. Cable exits are located in the mast heel casting. ------------------- unquote -------------------------------- The above may be of some help - provided there is a messenger line in the mast. Otherwise you will need to feed a new messenger line through the conduit in the mast. You can download the manual from Selden's website. Good luck
