Has anyone had this issue? This has caused the steps to pull away at the top where the hinges are screwed into the steps which make the latch at the bottom of the steps very difficult to open and close. Any suggestions for a fix.
I can’t recall exactly as it’s been a number of years (10) since I did it but I’m thinking I put bolts on the step side too. Wish boat wasn’t covered so I could confirm for youSounds like your repair was on the engine side of the hinge. These holes are striped out on the step side of the hinge.
Better IdeaI can’t recall exactly as it’s been a number of years (10) since I did it but I’m thinking I put bolts on the step side too. Wish boat wasn’t covered so I could confirm for you
Dont be shocked. Every boat is a compilation of compromises. And this is one that Hunter should not have made. Screws into particle board for a weight bearing application like this is a bad idea. The particle board just does not have the screw holding strength to support the weight of the stairs when in up position. I have had no issues since I went with bolts. I do always make sure to raise and lower The stairs carefully. Letting them slam upward puts a lot of stress on the screws.The hinges on my 38 are falling off too. I'll be looking at it in a week or so and pondering the fix. So far I like the through bolted suggestion as it sounds stout. But the insert fix sounds interesting too. Likely they used too small a screw for the job or the wood is not up to the task. IE too thin or too soft. I'm shocked that a boat manufacturer skimped on something.
Has anyone put longer support stays on the steps to hold them up higher ? Not even sure if its possible but mine are shot and I'm going to look into it.
Just completed the sale and when I get home from being out of town I've got a long list of things to look at but with the cold setting in I'm hoping for a few warm days to get more than the winterizing done.
Please look at my response re: using threaded inserts.There are a few youtube videos in Sail Life that use Forsner bits to drill out the hole quite large and then refill them. Makes the hole stronger and water tight.
Not exactly.... search Amazon for "threaded inserts" they look like thisGoogle “helicoil insert”.
Yes, this is exactly correctNot exactly.... search Amazon for "threaded inserts" they look like this
Helicoils are for metalNot exactly.... search Amazon for "threaded inserts" they look like this
