E
Ed Schenck
1) How has anyone, H37C or otherwise, repaired the cockpit locker seals under the cover edges? Mine are mostly missing. What is left is brittle and breaks off. Just clean it off and forget it? Or should the covers seal when closed? My covers/seats are at home for repainting and this would be the time to fix. 2) The screws that hold those two deflectors at the rudder go into a hollow area. Not sealed correctly you will get water in the bilge from those holes. Using a wad of newspaper and aluminum foil I stood on my head in the rear lazarette to make a template. It's about 14" top to bottom and 2" thick. The width tapers from over 4" at the top to less than 3" at the bottom. I plan to fashion something to fill that void and glass it in. Anyone look at this?3) Believe I have found the right color scheme for deck, trunk, and non-skid. I have been testing with a rear lazarette cover. I like a mix of 2/3 white and 1/3 off-white for the smooth. Gets rid of that "too white" look that is too bright(for my tastes). Then I am using a straight off-white for the non-skid. Looks good, or as good as paint can look compared to gelcoat.As always, thanks for sharing your experience.
