Has anyone done up a wiring diagram for their h340 ~2000? I'm working on tracing, documenting (and understanding as it seems an odd setup) ours but would help to have something to compare against.
I'm not sure whether some of this has been added post-factory or not but in our case we have:
-Start battery plus a house bank (2 x 6V)
-Standard 1/2/both/off switch
-An on/off switch beside it on the start battery
-Digital duo charge regulator
-Protech 4 charger
-Xantrex battery monitor
-Loads including engine, house, windlass, etc
As near as I can tell the start and house systems are isolated although what really has me wondering is the way the 1/2/both/off switch is used. It seems to always have to be in both for everything to work and the only connection to what would normally be the switch output is from one of the two Protech charger leads (the other goes straight to the house bank). It's almost as if the switch is for distributing charge vs power but not sure why...
I've added a pdf of what I've traced out so far...still a few unknowns and need to spend some time confirming but getting there...
Scott
-Protech 4 charger
Scott
