Jim Oursler in Rockwall
I have come to the conclusion that the capacity of my holding tank must be reduced due to years of buildup of stuff. It is the factory original plastic on a Hunter 34. I think that the boat sat unused for 3 yrs by prior owner. Repeated Vacuum pumpouts, refilling and pumping out clean water rinse as well, and still have very low capacity.Short of replacement, What chemical or procedure is recommended to remove the sludge? I have eliminated all source of water entry except the new head, completely closing off the thru hull, and removing pump and vented loop, as this boat is on an inland lake. Replace remaining hoses.. and at least have a good absence of odor.After just a few flushes, I find flushing causes water to come out the thru hull vent just below the rail.. and know it's again time to go to the pumpout station.HELPJim in Dallas
