Scraping the bottom to day and found two holes just above the keel bulb on the fin about 4" from the back edge. One hole on each side. They where both plugged with polysulfate compound and drain the fin aft section. The fin aft section was full of water which clearly had been in there a while.
Any idea if this connects to the bilges?
It looks like this is a factory installed weep hole. My concern is leaving an air pocket will increase my buoyancy (not much but she is tender enough as it is) or connect somehow to the interior of the boat and leak to the bilges.
