Some wisdom in @Freedom77 's post. As I mentioned in another post, the roller reef boom works great to let out a reef but is a PITA to reef in a blow. I did like the roller for storing the main and I usually left my cove with the sail partially roll-furled since letting it out is so easy if the wind was light once I got away from land. But once out, I slab reefed if I needed to shorten sail.J Brock. Spend the $$ and go to a sailmaker and get double reef points put in the main. I ordered mine when I got the boat. Good investment that will save a lot of problems. The roller reefing was one of Rogers goofs. By the time you need to reef you'll be in trouble. That's my story and I'm stickin' to it.
Freedom77,Also, while I'm on my soapbox, Mid boom mainsheet with a traveler.
