So, I am making arrangements now to drop my 302 keel and have it inspected. The previous owner had put a substantial amount of what appears to be 4200 around the keel to stub joint. When I hauled for the winter, I noticed a bunch of barnacles had dug well into the sealant. So, I am spending a great deal of time to remove this mess.
However, upon removing it, I noticed that the keel seems to be "off center" for lack of a better way to describe it. There is almost a 1/4' difference from left to right in some places. When viewed from the back, it can definitely be seen that it is not aligned. The front seam seems to be correct. There has not been any evidence of damage to the keel. I ran the boat onto a sand bar once, but it was very gentle on and a gentle pull off of it.
Has anyone seen anything like this before? (I know it's a little hard to see because I haven't finished cleaning all the 4200 off, and the light is bad on the second photo).
Unless someone else has any bright ideas, I can only assume one of two things:
1. The factory did a poor job of drilling the holes, misaligned it, and attached it that way.
2. Somehow, a bolt hole has wallowed wider and the rig has shifted starboard. I would think that this is unlikely, but I guess anything is possible.
Guess I won't be sailing until May some time.
