My '93 C34 has two starboard side water tanks. One is accessed under the starboard seatee. The other must be located in the vicinity of the aft cabin but I have no idea as to how to access it. If anyone knows how, please reply.
You have to remove the bulkhead between the aft cabin and the lazarette. To do that, you must remove the bulkhead between the aft cabin and the fuel tank, because that "wall" holds the port end of the aft "wall" in place. There are, IIRC, 12 screws for each. You may also have to remove the cover to the idler screws for thew steering overhead in the aft cabin to get the aft wall out.
You can get just about everything you need to know about your Catalina 34 at our C34 website and forum: Main Message Board
