Own a Hunter legend 37, it has been recommended to put in a #3 jib sail track for racing. the problem is that it would require a track to be put in on the cabin top, there is a hard liner on the inside and it looks very difficult to put a support plate in. Has anybody done this on a hunter 37..... if so, how did you do it, or how would you recommend to do it. The idea is that in heavy air, with a #3 sail, the boat points very poorly and was measured out at 15 degree sail angle where it needs to be more like 10 degrees.
