I did a bunch of testing on my 2GM20F Yanmar engine for a coolant leak. I sealed up the inner tube of the heat exchanger (after cleaning) and pressurized it and immersed in water, no leaks (looked like new inside and out) and also put the end caps back on the engine after removing the heat exchanger, using some home made flat rubber gaskets. I also put a hose between the fresh water input to the water output and bypassed the hot water heater, and removed the coolant input hose (on top) and used a 1 1/4" plug to seal that off. Using an air valve (like from a tire) fitting and a gauge, I pressurized the engine and found that there were no leaks. It held pressure just fine (Just a VERY slow leak down, probably from one of my fittings).
So, I'm starting to re-assemble. I ordered a new set of gaskets, but I'm concerned that the thermostat gasket doesn't appear to cover the top outer edge of the thermostat to hold it down. Like, with the thermostat in place (down in the slight groove) and the gasket over the top, you can remove the thermostat without it touching the gasket. I've done auto repairs in the past and the gasket always seemed to have a hole in the center for the thermostat, where it covered the outer edge of the thermostat.
I'm wondering if I should use some sort of gasket sealant around the thermostat and gasket...
There was no sealant around the gaskets of the heat exchanger when I removed it, so I probably won't use any around the rubber and other gaskets there.
While I was in there, I also removed the exhaust mixer and found that other than a thin layer of soot, it was pretty clear. I have a new gasket for that as well.
Mike
Mike
