fuel tank leak
N
ned crockett
After noticing diesel fuel in my bilge recently, I checked all fuel lines, filters, etc. and found all dry.Upon closer inspection of the fuel tank, I found all connectors dry but fuel under the tank. The tank was obviously leaking. It appeared that tank removal would be simple, but I should have known better. The locker opening is 14.5 inches and the tank is 15 inches in diameter! So, looks like I am faced with several options: remove the engine to get the tank out, cut the locker opening to allow removal of the tank, or somehow cut up the tank for removal. I would appreciate and welcome any suggestions, comments, experiences you may offer concerning my problem. If I can remove the old tank, I have found a replacement tank from West Marine that will fit thru the locker opening.
Nov 18, 2006
183
Kirie Elite Elite 37 Moss Point MS
options
Ned, i have a 1975 Pearson and have access through the Port quarter berth. Dont know if this came from the factory like this bout if so previous owner did a good job finishing out plywood panels using stainless screws and fender washers. Godd luck and let me know how things come out. Frank
N
ned crockett
fuel tank leak response
Many thanks for your reply, Frank. Taking the tank out of the quarter berth opening is not possible on my boat. I asked a boatyard mechanic to take a look at my problem and he seems to think the tank will fit thru the starboard locker opening after sawing off a lip. I have disconnected all fittings and the tie-down straps on the tank and will attempt removal tomorrow. Will let you know how it goes. I see you are in Moss Point. I spent nearly a year many years ago, 1960-61, at Keesler AFB as an enlisted airman learning electronics. I enjoyed my time there and always planned to return but never managed it. Hope you are enjoying your Pearson 30 as much as I am. Had a 1978 Pearson 35 for years. It was a great Chesapeake Bay boat, but with cruising days behind me, the 30 is perfect for the Rappahannock River day trips and racing. Ned
