Phil Ackerman
Does anyone know how to get the little round cap (with the screw in the center) off the motor mounted fuel pump on an MD11C? The point is to remove and clean a screen that is under the cap. Access is VERY limited and there doesn't seem to be a way to lift the recessed cap off of the pump. This is the tiny pump that has the spring-loaded lever underneath for bleeding the air out of the system.Regards,Phil Ackerman
