Actually it should be Fuel FilterS.
Ed:There actually should be TWO fuel filters for your engine. The primary filter may be a Fram (disposable), or Racor type of filter. There is also a small filter on the engine (small bowl on front of the engine). Many owners like to have a little amount of diesel fuel to fill the filters before they put them into their recepticles. This helps eliminate some of the pumping that is required. Once you have both of these filters in place you can loosen the lower bleed screw on the engine (this screw is actually 10mm bolt with a phillips head). Then you can use the thumb pump on the fuel pump. This may be difficult to find but it is on the starboard side of the engine (2GM), I don't know where it is on the 1GM. You will need to follow the fuel hoses back toward the tank to find it. Once fuel is coming out of the bleed screw (no more air), you can tighten it up. Quite often you do not need to loosen the injector side to bleed the engine. If the engine does not start, then you may need to bleed at the injector too.Run you engine in the dock in gear for 10-20 mins after you complete the process. This will be a good indication if it is going to stay running. PS: Get a Yanmaar Service Manual. Give you some idea of what to look for. You can get one from Mack Boring. There is also some other manuals available on these engines available at book store or Amazon.com
