I have been chasing a very small vacum leak for over two years, and I finally found it. I will admit to it being more luck than skill, and probably because it had gotten a tiny bit worse, and I would not have found it without having an electric fuel pump. What was happening that if the boat sat for a couple of weeks or more, the fuel system would have to be bled. It always started, then would run for about a minute, then die. Only bleeding the system would bring it back to life. I inspected, checked, re checked, replaced fittings, fuel line, everything I could think of, to no avail, and had pretty well resigned myself to live with it. This morning I was doing routine maint. getting ready to go sailing, when I noticed some moisture on top of one of the fuel filters. This boat has two big Fram filters, a water seperator primary, and a 10 micron secondary. They are cannister types, and the cans are held on by a single bolt in the top of the fitting. I had checked them a couple of times, and found everything to look perfect. They use a copper washer, identical to the Yanmar banjo washers as a seal under the bolt head. I do inspect them, but do not replace when changing filters, unless they are scratched up or look damaged in some way. To shorten the tale, one of these was leaking just a very tiny bit. I only noticed slight moisture, not any actual fuel. The washer looked like new when removed, but replacing it cured the leak, and very hopefully my problem. And incidentally, I have been using a fiber washer from Ace Hardware for banjo washers for some time now. They are 45 cents each, and much more important are available. I keep a bunch on the boat, but so far have never had one fail, or leak. I do replace these every time I take one off, and do not reuse them. I know the copper ones are supposed to be replaced each time too, but they are a little hard to come by around here. My closest supply is the local Yanmar dist. and it is a two hour round trip. Last time I went over there, they had 4 in stock. So, the fibers are a much more desirable way out for me.
