Forward Hatch Leak
1,944
Catalina 310 #185 Quantico
I have a very slight leak in my forward hatch that appears to be coming from the hinges. Has anyone else had this problem and what did you use to fix it? Would just taking the hatch apart, cleaning it off and applying a light application of silicon do the trick?
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
I had the same problem. They make a rebuild kit for the hinge. IIRC it came with new gaskets, O rings and sealant. It was under $20 at the boat show last year. Sorry I don't know where you can get one. Maybes CD or Defender?
Aug 24, 2009
444
Catalina 310 Sturgeon Bay, WI
I had pretty much the same issue. I cleaned the seal of all dirt, real real well and then applied Armor All to the seal to treat/soften it up a bit. Did the same to the O-Rings in the latch handle. All drips stopped. It's worth try.
Jun 7, 2004
10
- - San Francisco
rpwillia said:
IK and Long Story - Both great ideas.
Every year or two I clean all of the gaskets and apply a silicon cream that I got from a Honda dealer. They use it to prevent leaks and squeaks in sun roofs. Works very well.
