Engine Replacement
209
Hunter 34 Forked River, NJ
If your boat
has an Atomic 4 it is probably old enough to vote! Replacing the Atomic 4 with most anything else(diesel)is an error.You probably will never get your money back when you sell the boat.
RichH
Feb 14, 2005
4,773
Precision rebuilt A4 from Moyer Marine
www.moyermarine.com Then add fresh water cooling, proportioning cooling water valve, electronic ignition, electric fuel pump, PCV valve, etc. for bombproof operation .. about $6000.00 cheaaper than an oil burner and no need to change engine beds, prop/shaft, fuel system, etc. .... also offered by www.moyermarine.com or www.indigoelectronics.com
Steve O.
Universal?
I believe Universal has a model that drops in to replace the A4. Check Marine Diesel Direct on www. torresen.com Or you could go with a transom mounted outboard--much cheaper & easier.
David
I have no engine right now. Where can I get an Atomic 4? One that I can rebuld or one that has been rebuilt.
RichH
Feb 14, 2005
4,773
Moyer Marine
Don Moyer is the world's 'guru' on Atomic 4s. He rebuilds them to perfection. Go to www.moyermarine.com and then go to the 'quote' section of the website and enter the data for a quick quote. Then go to the 'upgrades' section to add all the modernization bells and whistles. www.moyermarine.com If this is confusing, simply CALL Don Moyer and tell him your situation.
