Dave
I purchased a 1996 C30mkIII with a Universal M25XP engine this spring and as part of the commishioning, I changed all the filters and the oil. I put about 60 hours on the engine and drained the Racor fuel filter bowl several times with never more than a tablespoon full of water and "Stuff". About half way thru the summer, I also took the tank sending unit out and used a hand pump to suck out the bottlom of the tank, got about a pint of water and "stuff". The Racor is a 220RS with a 2 micron element, placed before the fuel pump. (I also cleaned the screen in the fuel pump this spring) My question is, is it necessary to change the engine mounted fuel filter again this fall, if it has a 2 micron filter ahead of it?Part two of the question is that the electric fuel pump seems to only run when the key is in the pre-heat position and is not pumping in the run position or on position. Is this normal? Engine runs fine.Thanks in advance.Dave
