Electrical Panel Glass Fuses
Apr 7, 2012
1
Catalina 30 Charlottetown
I'm looking for information on obtaining replacement electrical fuses. They are glass tube, smaller than the auto fuses. They appear similar to the Ancor type fuses, however the dimensions are 30.5 mm long x 5.9 mm wide. The metal ends have a slight dome to them.
I'm looking for various amperages of 10 - 25A.
Any ideas on where to purchase these?
Jan 30, 2012
1,142
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
30.5 mm is 1.2 inches so that would probably be an AGC fuse (1.25" x .250" ). These are available at nearly all auto supply stores. The shape of the ends will not matter since a standard panel fuse holder keeps contact with the fuse at the circumference on one end and a spring contact at the other.
For further reference see Cooper Industries or Littelfuse. They both have a complete description of nearly every glass fuse imaginable - pictures too.
Your fuse is embossed on the metal end with the fuse type i.e. AGC, AGX, SFE etc
