Does anyone have experience with electromaax E-Maax Controller? Is it comparable to combination of Balmar 614 and Victron 702? I came across it researching an external regulator for my Aquamaax 140 alternator and planning installation of a battery monitor. It appears to be a new model that combines external regulation with battery monitor. I'm intrigued since I was looking at installing both the Balmar 614 and a separate Victron 702 battery monitor. Any insight would be welcome.
"It appears" leaves a lot to be desired.
I looked it up:
http://www.electromaax.com/products/e-maax-charge-controller-monitor-system/
The VOYAGER option requires you to purchase a separate shunt, which is NOT defined nor does it appear to be sold by Electromaxx as part of their package.
ITWMB, I'd get the MC-614 (I have a 612, great unit) and the Victron (you don't really need the 702, the 600 (?) single house bank monitor with voltage readout for the reserve bank), is pretty much all you need.
The Victron is a LOT easier to wire, too, as far as the monitor function.
The wiring for the regulator portion seems more complicated than the harness one gets with the MC-614.
woodster mentioned Maine Sail. Do a search on the topic and use Maine Sail as author and see what comes up. IIRC, he did discuss it in one of his many, many helpful posts.
