Hi Don!Here's a question I haven't been able to answer for myself. It has to do with the transition from the main generating lift (as on a beam reach) to the main generating only drag (deep broad reach and run) as you need to pick points of sail farther off the wind. Light and shifty winds on my long narrow lake make real testing difficult.When bearing off from a beam reach, at some point my mainsail and boom are up against my swept-back shrouds and spreaders. Let's say this happens when the wind is 110 degrees off the bow. Somewhere beyond this point, say 115 degrees, the wind no longer gets behind the main and it's generating drag only. At this point the vang and leech cord are tight to minimize spillage of air and maximize drag, but the main and boom are not perpendicular to the wind. Do I leave the boom near the shrouds, or do I pull the boom back 40 degrees to put it perpendicular to the wind? Pulling the boom back to place the main perpendicular to the wind would increase the sail area it presents to the wind, and minimize air spillage, but the larger force generated by the main is now a vector 40 degrees farther off the bow compared to when the boom was against the shrouds. Therefore, not all of the increased force would actually contribute to the forward direction, and perhaps it's even less?If pulling the boom back is the right thing to do, I could do so for all headings from that point until it hit the spreaders again, which would occur when the wind is 155 degrees off the bow. ...RickM...
