log calibration
Jim,As others have already noted you should check to see of your prop allows your engine to reach it's rated RPM. There should be a rating plate on top of the engine. On my 35.5 the 3GM is rated for 3400 RPM continously, and 3600 RPM max. Check your rating plate. You should be able to reach the MAX listed RPM at wide open throttle. If you cannot, the prop is oversize (or overpitched). If you could go to a higher RPM the prop is undersized (or underpitched). If the difference isn't very large, say a few hundred RPM, you can either live with it, or take the prop off the boat and to a prop shop. A good prop shop will be able to use a computer program to help them measure your prop and "tune" it to eliminate imperfections (slightly different pitches from blade to blade, which can make a difference)and adjust the pitch overall to increase or decrease "bite". This will slightly change the RPM - more pitch (bigger bite) less RPM and so forth. If the prop is about right i.e. the engine is close to max rpm at wide open throttle you need to look at the boats condition (i.e. is the bottom clean) and calibrate the log. I wouldn't compare the log to the GPS directly. There are to many other factors which affect SOG shown by the GPS to rely on it to accurately reflect log speed. You don't say what type of log you have or if you have the manuals for it. My boat has the Autohelm ST 50 in it, and it gives proceedure for log calibration. You can use a GPS to help you with this by setting a one mile course. I would suggest you run the course at least 4 times. This will give a fairly close calibration.Good luck
