Hopefully someone has already found a fix for this.
I lost all but my anchor light on the last trip so now that the boat is back at the studio I started looking into the issue. It turns out to be the same problem for the 2nd time now . The deck plug and 4 wire line headed under the deck are totally corroded again. Luckly where the wiring harness in the cabin ends is only has a slight corrosion on one connecter.The plug I've been using is from CD and I'm not planning on using it again .
I have a nice stainless steel connecter to change it out with but I need to do my due diligence with everything involved this time.
Thanks
Thanks
