After replacing two sets of batteries because of overcharging abuse I finally learned. I paralleled two 4D batteries and used an ACR to charge a starting battery, installed a battery monitor, shore charger with temp sensor, and hi-output alternator with temp sense on the alt and house bank. I monitored the SOC carefully, never discharged below 50% (ave 25%), monitored the water level. in short, I babied these suckers. Now, 4 years later, frustration.
This past fall, before closing for Winter I was testing to see if equalization was needed with a temp compensating hygrometer. All cells were in the green and within tolerance, except one. This cell on the end away from the posts, was flat: not short, not open, just flat. Zero, zilch, just plain water. The voltage on this battery was 10.5.
What could cause such a condition? Could I have failed somewhere along the line? Are batteries just prone to this type of failure? Is there any way to recover from a dead cell?
