Re: Daysailor II foam in the seat and bow tanks falling apar
Thanks Sunbird22358,
To dry things out, I do leave the leave the deck inspection ports open for a while, and yes, warm, sunny days do wonders for eliminating the moisture from Loose Lucy's inner hull.
To answer your Q: was it just wet foam, or did you find water?
I find water, and do as you suggest, I drain the water out through the D/S II Self Bailer port, stern drain plug to drain inner hull, and sponge out the water in the inner hull through the two deck inspection ports astern the Cuddy Door opening.
When I soak up the water in the inner hull, I can fell the foam. I believe it's the original foam as described in the "DAY SAILER, OSPRAY and JAVELIN RIGGING INSTRUCTIONS":
FLOTATION
There is sufficient foam flotation (in block form) in the seat and bow tanks to support the crew and normal gear, should a capsize occur or the hull become punctured.
Inspecting the bow foam thru the cuddy bow inspection port, like your boat, is just a lot of scrap foam pieces, and they remain dry.
The original foam in NOT closed-cell "Styrofoam", it is falling apart into various sized small round pellets. I see the pellets when the water is exiting the stern drains.
A sailor told me he uses foam "noodles" for his positive flotation material, I like your idea better. Am I correct to think that if I use closed-cell "Styrofoam" with expanding foam used to glue the blocks in place, even thou the water would still find it's way to the inner hull, the foam would not absorb the water and the water would exit out the stern drains when out of the water.
Again, thanks for your assistance,
Ahoy!
John
