My O'day 25 has one battery in the lazarett. I am planning on replacing the original DC breaker panel with a new Blue Sea panel. The original panel is on the bulkhead under the companion way and the back of the panel is between the bulkhead and bridge deck wall. It is open into the lazarett. Next to the panel will be a new battery switch. The battery is about 5 to 6 feet from the DC panel.
The Blue Sea instructions caution that the breakers are not ignition protected and should not be mounted where combustible vapors may be present.
Should I be concerned about the location of the panel being in the same open location the battery is in?
Should add that I have an outboard with fuel locker so that is not an issue.
