Head Light
Hi Linda, I put a pedastal light, swivel base flush mount type, in the head over the sink. The wiring was pretty tricky but not impossible. I used coat hangers to thread the wire up into the area behind the round plexiglass panel. I had to run the wire from the fuse box on the port side all the way aft, across the boat to the starboard side, up the starboard side to the head. I tucked the wire up under the deck liner as I went and then behind the "decorative" panel aft. The hardest part was threading the wire from the rear birth starboard side up into the head. I first had to snake it into the head by running a coat hanger from the head into the aft birth under the deck liner. Once I got it into the head I used the coat hanger again to snake it up to the space behind the plexiglass panel. This whole project included a light in the overhead area of the port side aft birth, another in the starboard side aft birth and then the final one in the head. I suppose you could try a more direct route from the light over the dinette, but I couldn't figure out how to access this one very easily. Good luck and happy wiring! Kevin Newmarket NH
