Hi All,
Is someone making the flat crossbar for halyards I am seeing for racing?
That's true, but it looks to me like you could close the companionway overhead slat and just let the lines drop into the floor of the cockpit (which no one likes). Personally, I'd install some of those bags that snap onto the backside of the companionway wall:the lines run into the cabin...
Which is exactly where they should be. Best place for lines.But then if you leave the slider open, the lines run into the cabin...
I was thinking the same thing! But I can honestly give them credit for having the cleanest looking Cat 22 I've ever seen...what is chubby doing sitting in the bow pulpit when sailing downwind? Look at the bow of that boat dig into the water!
For storage for sure. But for sailing (and in particular racing) lots of lines need to get out of the way fast, and and even more importantly come back up clean. So down the hole they go. That bag might work as working storage for two lines, but how about 16?That's true, but it looks to me like you could close the companionway overhead slat and just let the lines drop into the floor of the cockpit (which no one likes). Personally, I'd install some of those bags that snap onto the backside of the companionway wall:
Kinda like that. My friend's Cat 27 is just like that, and it works great!
That's a good point. That's what I did on the Sonars, was just toss em' down in the cabin and it worked fine, the only problem being that when it came time for someone to grab the halyard, they had to reach down into the companionway and make sure the line wasn't wrapped around anything (whisker poles, spin poles, spare fenders, ditch bag, etc.). In a larger cabin like the 22 has, though, I'm sure that isn't an issue.That bag might work as working storage for two lines, but how about 16?
You can always get one of theseJust did some more thinking...I'm not sure about your boat, but my Cat 25 doesn't have the proper rig for this setup, because the halyards aren't run through a set of blocks at the tabernacle, as shown in the picture. This means I would have to add those blocks and reinforcement beneath them in order to have the halyard running the right direction, and you might have to do the same. Honestly, that's a lotta work, but I'm sure it'll be worth it after it were finished. You've got me thinking now!
Most likely this is a custom piece built by the owner of this boat. However the C 22 racers are a great group and are quick to share ideas / designs. I would try contacting the racers on the Facebook group or through the Catalina association website. I am sure the chief measurer (email on the association website) could put you in contact with the right people. Otherwise check the tech manual as there is likely an article in there about running your halyards this way.Hi All,
He is there to help the boat gain speed downwind. While perhaps he could sit a little closer to the cabin top all racers of C 22 put a man on the bow going down wind. The stern of the boat is very heavy and with the required class weight of the outboard on the stern it amplifies the problem. Placing a man on the bow lifts the stern and increases down wind speed. I put 2 or 3 kids on the bow when I race and can speak from experience that it makes a big difference when racing JAM down wind like the boat pictured.what is chubby doing sitting in the bow pulpit when sailing downwind? Look at the bow of that boat dig into the water!
I'm buying one this weekend. Said and doneYou can always get one of these
Possibly getting the transom up out the water to create less wake drag??? We do this on our smaller dinghies... especially on the run downwind.Which is exactly where they should be. Best place for lines.
BTW - what is chubby doing sitting in the bow pulpit when sailing downwind? Look at the bow of that boat dig into the water!
Flatter is faster, that's what I've learned. Oddly, however, different tactics downwind can make all the difference when it comes to gaining any ground in a race. For example, when my brother and I raced FJs this past summer, we were one of the heaviest teams out there. In order to gain as much of an advantage as possible, we would try all these different tactics downwind to gain more speed since we were heavier; we found that the Brazilians and South Africans were using this tactic: They would pitch the boat hard to starboard, placing the main high in the air and the jib beneath, almost as if they were using the rig like a horizontally mounted kite. The first couple races, Zander and I retorted them for doing this, but found that it actually did work when we gave it a try.Possibly getting the transom up out the water to create less wake drag???
Yep... putting the main way up there to catch the wind is good practice! ... just don't Jybe,,, We also teach our young sailors to roll their boats very strongly to windward just before tacking so that after tacking bringing the boats upright will give the boat a scoot along on the new tack... especially in light airs!Flatter is faster, that's what I've learned. Oddly, however, different tactics downwind can make all the difference when it comes to gaining any ground in a race. For example, when my brother and I raced FJs this past summer, we were one of the heaviest teams out there. In order to gain as much of an advantage as possible, we would try all these different tactics downwind to gain more speed since we were heavier; we found that the Brazilians and South Africans were using this tactic: They would pitch the boat hard to starboard, placing the main high in the air and the jib beneath, almost as if they were using the rig like a vertically mounted kite. The first couple races, Zander and I retorted them for doing this, but found that it actually did work when we gave it a try.
Yes, the roll tack is an absolute MUST. If you don't have that down, you're not a real racer yet ! Also, I believe the biggest threat while pitching downwind was keeping the boat in that position; the reason for this is because the rules clearly state that a boat cannot be rolled downwind in attempt to gain speed. While pitching the boat, sometimes the wind and waves would take over, pitch the boat back the other way and start a rolling motion, resulting in a direct penalty.roll their boats very strongly to windward just before tacking
