Crazed hatches, ports
Jul 19, 2013
11
beneteau 393 san francisco
Hello-
All my hatches have crazed cracks.
I've been told that this does not affect structural integrity. True?
Short of buying new hatches, can anything be done about it?
Thanks
Dave
Gunni
Mar 16, 2010
5,937
The solution is lens replacement. Select Plastics. You need to remove the hinge pins and split the hatch frame apart. Get the gasket set too.
Apr 25, 2010
35
Beneteau 331 Herrington Harbor South (Friendship, MD)
Headlight and Clear Plastic Restoration Kit
The catamaran a few slips down swears by the Headlight and Clear Plastic Restoration Kit by Meguires -- the stuff you use on your car’s headlights when essentially the same things happens to them. He said he used it and his ports and hatches look good as new. I bought one to do to my hatches and ports. I figure given the cost, if I have to replace them, might as well try this first and see what happens. If I get to it sooner rather than later I will post pictures.
