I haven't seen any hint of "old car" oil smoke in my exhaust since my arrival in Oxford. I think the heavy motion and pitching on the way up was probably the cause of what I saw a couple weeks ago.
Nevertheless, being an inveterate fiddler, especially when it ain't broke, I decided to reconnect the oil separator. First however, I took Mainesail's suggestion and unscrewed and removed the filter element. It did not seem very oil soaked and I could blow through it effortlessly. I think it's overkill though. The filter bowl now serves as simply a sump. Any liquid oil going through the line should simply fall into the bowl. This will let me assess how much oil may be going through the breather hose and keep it out of the engine.
If the separator should fill up, I shouldn't be any worse off than if the hose were simply filled with oil. I'm not concerned about the slight additional restriction of a foot of hose, and elbow and a nipple now that I have positive suction on the hose at the manifold end. If any liquid oil does get in, restriction should be less with the oil drained off into the bowl instead of needing to be pushed/sucked up the slope to the manifold connection. I'll keep a close eye on it though.
