E
eric linklater
I have finally begun the work of dealing with the leak from the mast conduit. I found that the compression post was rotten for about 4" at both ends. Also the wood inside the fiberglass bulkhead is rotten too. Can anyone tell me how much wood is in this bulkhead? Does it go all the way to the sides of the boat as the bulkhead does? Can I cut a hole thru the bulkhead where the post used to sit and install an aluminum post full length rather than cut out the bulkhead and remove the rotten wood and install an aluminum block? I am afraid of weakening this bulkhead by taking a chunk out and trying to reglass it afterwards. Any information anyone has about this would be appreciated. I have already downloaded all the info from the step by step instructions and pictures that one owner placed on this site but I want to consider options.Eric Linklater"Worlds Away"
