Cold Weather Sailing Prep - Alabama
JRT
Feb 14, 2017
2,046
The hold my beer state has decided that we will go from 70s to a freeze warning in less the 24 hrs, so fall is done and winter is here. We usually don't sail in 40-50s but next weekend is the annual Great River Race and Abby and I have to defend our 2nd place finish from last year. We are racing our 310, which we have only had since April, and my parents have asked to come. I've prepped them on it will be cold and to bring layers and blankets. The 310 has all lines to the cockpit so there will be limited need to leave it. Cabin is comfortable, but heat is not available without shore power. This will be a test for sure and my daughter and I are really excited. We have told crew that I and Abby make the call and be prepared for a 10-12 hr day on the water.
Likes: JamesG161
Nov 6, 2006
9,892
Always a hoot! We enjoy "cold" weather sailing on Lake Pontchartrain, and if ya stay bundled up, you'll have fun !!
Picture is on a local bayou in December a few years ago.. temperature was about 28 F .. eerie ice fog thing ..
Nov 8, 2010
11,386
Maybe better post in racing then in weather, but here goes.
the first trick is to stay on top of the Cold. Layers. Merino wool on the bottom, take on and off upper layers as needed.
When it gets cold, keeping the wind off of you is key to warmth.
On BlueJ we use a MrHeater Buddy mounted to the bulkhead. Thing pumps out the heat and is safe inside. 2-3 1lb can will keep you toasty all race.
JRT
Feb 14, 2017
2,046
Oh that is perfect, at Home Depot so I'll grab one tomorrow and this will be perfect, thanks @Jackdaw
Racing crossed my mind for this post but it is about comfort, I sent the link to you 40s final race as right now that os looking like our conditions and wind predictions.
Likes: Jackdaw
JRT
Feb 14, 2017
2,046
Got it and a 4 pack of tanks, should be set now!
Likes: Ward H
Ward H
Nov 7, 2011
3,649
Catalina 30 Mk II Barnegat, NJ
Long john underwear has come a long way since I last purchased some many many years ago. Merino wool long johns, hat liner, socks and glove liners are what I use for sailing in the 40s and 50s.
Likes: JRT
Nov 6, 2006
9,892
+1 on Mr Buddy! Bought mine a few years ago and love it. It was warming the boat when that picture was taken . Mighty nice to warm the boat in the morning.
I went sailing yesterday on Lake Martin AL. The wind was gusting and I was by myself so I flew the head sail only. Made hull speed a few times but mostly an easy drift across the lake. Hope your race is fun an relaxing.
Aug 17, 2015
3
Pearson 39-2 Milwaukee
Timely topic! I had that same heater and loved it but it stopped working after a couple months.
Word to the wise: Carbon monoxide is not your friend.
Yes merino wool inside, layer of fleece over that, something windproof and waterproof over that, and switch to a PFD with some insulating value if you normally use an inflatable . I just did a couple eight eight hour watches in wind and rain bringing my boat down Lake Michigan from up north. Uff da.
JRT
Feb 14, 2017
2,046
Well the race was cold as predicted but the Mr. Buddy was a big hit. The cabin stayed warm with the sunny day and Mr. Buddy was positioned in the cockpit under the table. We had so little wind so it was a slow drift fest and barely any heel so the heater was easy to keep stable.
11,386
For sure re CO. But boats are very leaky air-wise. We Also have 2 CO detectors hard wired in the boat. That’s a law in MN.
Likes: JRT
Nov 8, 2010
11,386
Will the race was cold as predicted but the Mr. Buddy was a big hit. The cabin stayed warm with the sunny day and Mr. Buddy was positioned in the cockpit under the table. We had so little wind so it was a slow drift fest and barely any heel so the heater was easy to keep stable.
If you notice, there are two mounting points on the back to hold it to a bulkhead. It holds it very well in crazy conditions, but still lifts off for storage. If the unit happens to tilt more than 45 degrees, it will turn off.
Likes: JRT
Apr 5, 2009
2,783
It is too late for your race but for others going out in cold weather, your foulies are your best friend in the cold. Put on warm layers and cover top and bottom.
JRT
Feb 14, 2017
2,046
I did see that and it will be improved next time out! The layer approach worked well for us, we lived in Maine and Rhode Island so we have this down. I start off will bundled up and as the day warmed or I was out in sun more I adjusted. I also limited all movement outside the cockpit to myself, my daughter and my son only and we all had to have the inflatable vests on to move out of the cockpit, water temps were 57 degs. I actually had mine on the entire day and did most of the forward movement.
JRT
Feb 14, 2017
2,046
We didn't run it in the cabin a all, but I installed a new CO detector the week before also.
